The fourth-generation Surface Pro tablet, released October 26th, 2015.
208вопросов Показать все
Why does my battery replacement say "0% available, plugged in"?
Hi, I don’t know where else to look. I bought an iFixit battery and put it in an SP4. It turns on with power adapter connect, but turns off immediately after you unplug it. I tried going to device manager and uninstalling the battery driver + doing a full reset (via power + volume up)…nothing. I ran “powercfg /batteryreport ” and it recognizes the battery and says it’s fully charged.
Edit: a co-worker tested the capacitor that is known to fail and it is good.
Installed batteries
Information about each currently installed battery
SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 4
BIOS 109.3192.768 03.24.2020OS
BUILD 19041.1.amd64fre.vb_release.191206-1406
PLATFORM ROLE Slate
CONNECTED STANDBY Supported
REPORT TIME 2021-04-0708:54:45
BATTERY 1NAMEX910528
MANUFACTURER DYN
SERIAL NUMBER 39167
CHEMISTRY LION
DESIGN CAPACITY 35,250 mWh
FULL CHARGE CAPACITY 33,172 mWh
CYCLE COUNT-
2021-04-0606:19:29Connected standbyBattery100 %35,475 mWh07:18:40Connected standbyAC100 %35,422 mWh07:18:54ActiveAC100 %35,422 mWh07:19:59Connected standbyAC100 %35,422 mWh07:19:59ActiveAC100 %35,422 mWh08:24:23Connected standbyAC100 %35,422 mWh08:30:33ActiveAC100 %35,422 mWh09:34:53Suspended100 %35,422 mWh09:57:59ActiveBattery100 %35,422 mWh10:00:07ActiveAC95 %33,667 mWh10:58:36Connected standbyAC100 %35,520 mWh11:07:01ActiveAC100 %35,520 mWh11:52:24Connected standbyAC100 %35,520 mWh12:02:53ActiveAC100 %35,520 mWh2021-04-0708:54:33Report generatedAC100 %35,520 mWh
Это хороший вопрос?
Оценка 0
1 Комментарий:
I have been having this problem on an old Toshiba Equium with a old original 14 year old battery, its strange that this is happening on a new battery!
из
Добавить комментарий
1 ответ
If your laptop is unable to run off battery then try turning off your laptop and let it charge for an hour or so. If the battery still does not charge most likely the cells in the battery have dropped below the allowable low voltage because you have not charged the battery in a long time, the battery protection circuit might have kicked in to prevent charging the battery for safety reasons.
Try the following methods.
https://www.cnet.com/how-to/how-to-fix-a...
https://www.minitool.com/news/windows-10...
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Thanks for responding. This is a new battery that I bought from iFixit. I have charged is on and off. I used a different charger, and for a brief period it was fluctuating from 0% to 100% then back to )5, etc...
I tried both ways in the links you posted, as stated in my description. Though, I didn't uninstall the drivers and disconnect the battery to the Surface Pro 4. I will try that.
из
@crucier Sure, keep me posted, thank you!
из
Добавьте свой ответ
chris rucier будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 28
За всё время: 1,544
