A more affordable, purely handheld version of the Nintendo Switch game console, with integrated Joy-Con controllers and a slightly smaller screen. Released September 20, 2019.
Replaced left joystick and now screen doesn't work
I dropped my Switch Lite and the left joystick snapped off.
I was able to connect a Pro Controller until the replacement joysticks came in so I know the unit was working. Bought a 2 pack of replacement sticks. Neither replacement worked and now my screen doesn’t work.
Unit has power. Sound works for all of the buttons & the right stick. Even the left stick makes the boing sound when pushed in but not other sounds up/down, left/right. I only removed the daughter board when replacing the left joystick so I can’t see where/how I could have unplugged the screen.
Это хороший вопрос?
Счет 3
Добавить комментарий
4 Ответов
Наиболее полезный ответ
The screen ribbon cable connects to the daughter board right next to the power button ribbon cable. Make sure it’s properly seated and also inspect for damage.
Был ли этот ответ полезен?
Счет 1
How is it now? Is it fixed?
Счет 0
I have this problem too, tried reseating the ribbon cable a couple times but no luck what do I do?
Счет 0
I had this issue as well a couple of years ago with my Switch Lite and I got it working by taking a Q-tip and isopropyl alcohol cleaning the LCD cable to the best of my ability then making sure it was seated properly. what caused it not to work for me was that I had gotten a little bit of thermal paste on the LCD cable that i didn't notice and cleaning it helped so maybe you can give that a try.
Счет 0
Добавьте свой ответ
kai mpqii буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 21
За всё время: 3,127
