Repair and disassembly information for the Samsung Galaxy Note20 Ultra Android smartphone. Released in August of 2020.
46вопросов Показать все
Are the Note 20 and Note 20 Ultra loud speaker interchangeable?
I need a note 20 ultra loud speaker but no one in the usa has it in stock and I having a hard time finding the part. Theres some companies that have the regular note 20 loud speaker in stock and it looks similar but cant tell if theyre the same part. Anyway also if anyone can point to the right direction where I can find the part if theyre not interchangeable. Thank you
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Unfortunately they are not interchangeable and you would require the part specific to your device. You should be able to find the replacement part you need online. Just make sure to try get an original or genuine part as it’s less likely to fail or have any defects.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Andy Chaides будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 117
