Broke the LCD thermal sensor
So I accidentally ripped out my LCD thermal sensor, but luckily the cable is still intact. Unfortunately, I broke the plastic that keeps the cable in. I think the copper connection things are still in-tact but they are really tiny, I don’t know much about computers so it might be completely fine that it’s tiny but I just want to make sure.
How would I go about plugging the LCD thermal sensor in? Should I try to bend the copper connection things down to connect with the cable? Or is there a better way to do it? I’m open to anything, except soldering please.
Это хороший вопрос?
Счет 0
1 Комментарий:
Hi,
I think your best bet would be to assess the issue properly. I am assuming that the connector on the logic board has come out. See you can re-insert the plastic housing. Sometimes this is possible.
из Поделиться
Добавить комментарий
