Kenwood: First fridge stopped working, then freezer
Hi. I bought a Kenwood refrigerator just under 3 years ago. Never had a problem until around a week ago. Out of the blue, one day, the fridge’s cooling went down quite dramatically. By the night, it wasn’t working at all.
After reading a few theories online, I decided to turn the whole device off for the best part of the day and let everything melt, specifically in the freezer where a lot of ice had built up.
When I turned it back on, the situation was pretty much the same. The fridge wasn’t cooling at all; just the panel at the back was slightly cool to the touch, but the temperature inside wasn’t cool at all.
In the meantime, the freezer was functioning perfectly, so I continued to use it as normal, though I removed much of the contents and stored them in the deep freezer, leaving it mostly empty. Due to COVID restrictions, it’s not a very straightforward process to call a repairperson at home right now.
The freezer worked well for around 5 days, but since last night, the ice in it (and everything stored in the freezer) started to melt. I figured that I should turn it off once again for a while. I let all the ice melt, cleared it up, then turned it back on later.
Since then, the freezer is now essentially in the same condition as the fridge. It’s slightly cool to the touch, but it’s not cooling within the compartment at all. It appears that both fridge and freezer are now in the same state, and they aren’t providing any cooling at all.
I don’t have previous experience with refrigerators and don’t really know what the issue could be. I’m prepared to call a repairman now since the problem seems to be quite serious. However, I just wanted to check and see if anyone can share tips as to what the possible reason could be.
TIA. Much appreciated.
Это хороший вопрос?
1 Комментарий
I bought the Kenwood but I don't know how to start it.
из Segun Ladeji Ayinla
