After replacing Front Panel - weak Wifi Signal strength?
Hi,
I successfully replaced the Front Panel (with some drawbacks, I broke the Volume/Power Flex Cable while disassembling the iPod) but now the Wifi Signal strength seems lower than before, especially when my hand is in the near of the upper left corner where the antenna is located.
The Wifi Antenna is still connected to the logic board (I guess, as I would'nt have any signal if it was disconnected?).
I don't remember if there was any connection between the Wifi Antenna and the iPod Steelcase for better connectivity.
Has anyone had a similar problem?
Greets
Это хороший вопрос?
1 Комментарий
Checked the connector of the wifi antenna, perfectly connected. The antenna seems a little bit wrinkly, maybe thats why the signal is weaker.
I think I have to live with it, too afraid to break the power/volume cable again if changing the wifi antenna.
из Erich
