Why is it slow to boot up
very slow to boot up and runs slow after installing big sur
Это хороший вопрос?
Это хороший вопрос?
If your computer still has a standard hard drive or fusion drive, I’ve noticed quite a lot of them running very bad on BigSur. I would suggest either replacing the hard drive of the fusion drive with a 2.5 inch SSD or going back to macOS Catalina.
Был ли этот ответ полезен?
Where is the hard physically located? I'm having a very hard time disconnecting the cables from the display or the chassis. I have purchased a SSD that I will try to install if I can get there.
@ldonj - follow this guide iMac Intel 27" Retina 5K Display 2019 Hard Drive Replacement
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 286
1 Комментарий
Reboot your system and press the D key to enter into diagnostics. Did you get any errors?
Reference: Mac startup key combinations
из Dan
