Charging of the battery
Why does the charge of the battery get down from 100 to 96 while the Mac is shutdown?
Это хороший вопрос?
Это хороший вопрос?
Because your system is not fully off, its just in standby. So you’ll find the battery will slowly drain over a week.
To be sure and get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
Был ли этот ответ полезен?
it takes from the battery 3% however I fully off the devices (shutdown), however I left the device in shutdown for 6 hours, I added the the screenshot
@zyad housam - TouchID logic will slowly drain the battery. Its possible you have something else which is draining the battery like a failed component or corrosion damage.
This is still quite small to fight over and the costs could be expensive to fix. Take your system to an Apple Store to get an estimate to fix (should be free)
Alright, thanks
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 63
1 Комментарий
Reference: Log out, sleep, wake, restart, or shut down your Mac
из Dan
