detected by computer but won't turn on after being unplugged
i found an old shuffle while digging around a drawer and wanted to try it out, it syncs and is detected by itunes (flashing orange light) but won’t even function by itself
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
I had this exact issue with one I was given by a friend a few years back. The internal voltage of the battery has likely dropped to far and it has gone into “sleep” where it will refuse to accept a charge in order to prevent anything bad from happening (battery swelling/exploding). To fix this guy, you will probably need to get a new battery and install it. Not the easiest thing in the world, but it can be done. iFixit has a guide for removing the battery and logic board, from there would need to de-solder the old battery leads and solder in the new one, then re-assemble.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
turns out it just needed a good long charge, everything is good now!
из
Добавьте свой ответ
Luke Timothy Davis буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 14
За всё время: 137
