The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
389вопросов Показать все
xbox one s wont turn on and makes clicking sound then turns itself off
been doing this since last month, i try turning it on but everytime the xbox light lights up makes the starting sound, then after about a milisecond i hear a faint *click* and it shuts off right after, please help?
Это хороший вопрос?
Оценка 2
1 Комментарий
I also have these problem
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
There are several things that may be causing this. It sounds like it may be a problem with something shorting or with the power supply. It is most likely the power supply. Here is the part you will need to fix it if it is in fact the power supply. Xbox One S Power Supply: Internal Replacement Part (ifixit.com)
Xbox One S Power Supply Изображение
Продукт
$29.99
Был ли этот ответ полезен?
Оценка 1
4 Комментариев:
It sounds like it would be the PSU.
из
@nytryder26 That is what I thought, too.
из
I have this same problem, baught and replaced the PSU, and it is still beeping/clicking, could it be the motherboard?
из
@Russel Hill Maybe try the Hard drive
из
Добавьте свой ответ
eoinye10@gmail.com будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 10
За последние 30 дней: 38
За всё время: 113
