6th generation of Motorola's Moto G line. This phone was released in 2018 and features a glass back that is easier to remove than Samsung phones. Model numbers are XT1925-4, XT1925-5, XT1925-6, XT1925-12 and XT1925DL.
34вопросов Показать все
Where can I get a new charging port
My charging port overheated. I can not locate a new one. Data from my phone is lost until I find one. Help!
Это хороший вопрос?
Оценка 0
1 Комментарий:
try to carefully clean it. Overheat does not generally totally destroy it. get also new (good) cable. if the phone is ON, then you can use google drive or dropbox to copy all data. can you upload photos here of the port?
из
Добавить комментарий
1 ответ
Depending on what model you have, the port may be soldered to the main board. If that’s the case you’re going to want a specialist to handle it.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Paula будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 19
