Tickle Me Elmo is a children's toy from Tyco-Preschool, based on the character Elmo from the children's television show Sesame Street. It was introduced in the United States in 1996.
16вопросов Показать все
The batteries corroded in elmo’s foot can this be repaired?
  • The batteries left in Elmo and corroded can this be repaired. The springs are corroded and broken
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Pamela Adams you could most likely solder new contacts/springs in its place. Post some images so we can see how bad the damage is and where to attach the new ones. Adding images to an existing question
Update (07/03/2021)
You could get some wire and solder it onto the spring part. You could even bring some wire from the out side through the case. Of course I would suggest that you replace the spring contacts with something like this
Instead of cleaning it with baking soda use a diluted lemon juice solution to resolve some of the rust and debris from the alkali of the batteries. Once cleaned use a lightly oily rag to wipe down the lemon juice and lubricate the contacts.
Not a real bad repair and not to expensive
Был ли этот ответ полезен?
Оценка 2
I have had Luck with backing soda and water. Or de-oxit. And some time and patience.
Оценка 1
Добавьте свой ответ
Pamela Adams будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 375
