Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
323вопросов Показать все
After fall digitizer broke and back cover edge is a little bent
iPad 2 has fell on the ground and the digitizer broke. Unfortunately the edge of the back cover that hit the ground is a little bent too.
Is there any way to avoid replacing the back cover?
If I try to install a new digitizer without replacing the back cover will I have an issue during the installation?
Thank you in advance!
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
по рейтингу 0
Добавить комментарий
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
2 Ответов
Выбранное решение
Theo,
Unfortunately you need to replace the back cover as well. Even if it is slightly malformed the new glass will not sit down and you will either be breaking it again or fighting it trying to keep it stuck down and dust and dirt will get inside.
Был ли этот ответ полезен?
по рейтингу 2
I attempted repairing my housing, and it's not bad I would say, I used a mini chisel with pointed ends, after taking the skinny plastic frame off...
Now it's not skewed, and have fitted it back in and taped it up from the outside to see if it's a perfect fitt.. Well it will never be perfect, but as long as its out of the way of the digitser glass...
по рейтингу 0
Добавьте свой ответ
Theo будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,359
