I lost the right speaker zip connector latch
Is there something I can do? I can’t find the info about the exact connector model…
Это хороший вопрос?
Это хороший вопрос?
Found it! BMU Cable Connector
You’ll want to carefully lift off the clamp bar off the new part and carefully slide it in. You may want to get a few just in case!
Был ли этот ответ полезен?
Thank you so much! So it's the same as the old mbp battery connector? even if it's for the speaker?
@vincy722 - You're thinking a connector is always defined by its function. So If I use a power extension cord for speaker wires does that mean I can't use it? No!
The physical aspects of what the connector is (or cable) doesn't always define its use. Here Apple used the same connector for the speaker (saving them having to source a different part needlessly)
Thank you for the clarification! I'm pretty new to all of this... ?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 93
