The Xbox Series X is Microsoft's next-gen 4K gaming console. The Xbox Series X was released alongside its companion console, the Xbox Series S, on November 10th, 2020.
66вопросов Показать все
Xbox series x fan clicking noise
So sometimes the fan of my Xbox is emitting some sort of clicking sound as if it is touching something although it isn't. I'm assuming it's some sort of ball bearing issue. Any ideas what it might be? And if it's the bearings: is it ok to just leave it if the noise isn't bothering me?
Это хороший вопрос?
Оценка 0
1 Комментарий:
Im getting the same issue on my series x consolw aswell
из
Добавить комментарий
3 Ответов
Try taking it apart and check if the bearing is broken or something is wrong with the fan.
Был ли этот ответ полезен?
Оценка 0
I managed to resolve this, no need to open the console.
Stand xbox vertically and with front facing you
Through the vent at the top with a small screwdriver i kept turning the fan slightly until i could see a group of black cables clipped together through a gap in the fan blades. (Just right of centre at the front, nearest to you)
One of the cables was raised out of the group so i pressed down firmly on it and it is no longer catching the fan blade, been perfect since.
You may need a flashlight to shine into the vent
Hope this helps
Оценка 0
What was the sound like exactly? Was it loud? Was it a constant noise? I hear random noises from my console as well and I tried looking for this but saw nothing
Оценка 0
1 Комментарий:
из
Добавьте свой ответ
Atraks будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 26
За последние 30 дней: 160
За всё время: 12,324
