A2115 / 2019 / Processors from 3.0 GHz 6-core i5, up to 3.6 GHz 8-core i9. Released March 19, 2019.
131вопросов Показать все
No joy after upgrading
My hard drive went out . So I got the bright idea to swap it out. While I had it out I decided to swap out the i5 processor with an i9. I have done many many many pc upgrades no problem. But alas my iMac has said no. Now with putting it all back together only the 2nd light of the 5 leds comes on and stays on when plugged in. I have taken everything back out and ensured it is all plugged back in accurately. Why would the first light not light up? Also nothing seams to happen when pressing the power button.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Sounds like you have a bent pin or the CPU is not properly seated. That always ends up being the issue!
Был ли этот ответ полезен?
Оценка 0
Turns out there was a bent pin on the board, and I bent more trying to unbend it. I wish they would have just stuck with putting the pins on the chips much easier to deal with. Now I’ll have to get someone that can actually see them to fix it.
Оценка 0
Добавьте свой ответ
zyi_oct_1976 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 61
