Lenovo Y540 randomly turns the screen off.
my Lenovo Y540 randomly turns the screen off. The only way to get it to work again is to hold the power button to turn the computer off, and then power it on again.
The PC is turned on the entire time that the screen is black. While the screen is out, the power button is on, FN button on the keyboard is on, caps lock activates/deactivates etc. Everything indicates that the PC is running, but the screen randomly dies. Turning off the PC, and on again works 100% of the time.
I haven't been able to find a similar case to this, so I hope there's help out there!
I have tried the following:
Plug out the battery and hold the power button for 30 seconds
Reinstalling the PC with a fresh installation of Windows 10
Charged it all the way up to 100% power.
Это хороший вопрос?
4 Комментариев
I have same issue. Did You find the solution?
из Rafal
Sorry , No, I didn't
из Tech Gen
Hi @Tech Gen
You haven't mentioned if you tried what @jayeff suggested.
из mike
I've tried to reinstall drivers but issue remained, but I am 99% sure this is indeed nvidia driver problem as when I terminate nvidia processes on system tray everything is working, but after some time nvidia lunches automatically and then screen goes balck again. The reason might be also some win10 update which causes conflict with nvidia driver, but couldn't find any threads on other forums with similar issue. Apparently, this is not so common issue. The other posibility might be that after uninstalling nvidia drivers from system, it still keeps some files in the register that are causing the black screen issue. If You will manage to fix it. pelase let know. I wil also keep You posted if find a solution.
из Rafal
