Выпущенный 16 сентября 2016 года смартфон нарекли iPhone 7 Plus. Вышло несколько моделей нового устройства: A1661, A1784, и A1785, а также можно было выбрать между версиями на 32, 128 и 256 Гб встроенного накопителя. На выбор можно было приобрести золотой, розовое золото, серебристый, Jet Black и (PRODUCT) Red оттенки корпусов.
1364вопросов Показать все
Why wont my phone turn on?
So yesterday at around 11am, my phone turned off suddenly. I thought that it must’ve run out of battery so I plugged it in to charge but after around 24 hours it still had not turned on. Even when you hold the power on/off button, the battery symbol does not appear. The screen is completely black. I’ve tried countless things such as heating up the back with a hairdryer (this may sound quite stupid but many people said this worked). I’ve also tried to connect it to iTunes to reset it but I need a code sent to my (broken) phone to sign in. I’ve tried but failed to put it into recovery and dfu mode as well. I’m stumped on what to do next so if anybody could help me I’d really appreciate it :)
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
There could be a few things at fault here. I would first try another charger. If that doesn’t work, it might be worthwhile to either take it to a reputable repair shop (independent not “certified”. I know that sounds crazy but a “certified” shop will give you a certified “BS” answer whereas an independent will take the time to thoroughly diagnose it). You could also invest in a USB ammeter here on amzon: https://www.amazon.com/DROK-Multimeter-M... and this will give you a general idea of what’s going on like whether the device is taking a charge at all or if something like TriStar is damaged.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
keziah pls будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 21
