I replaced the battery on MacBook Pro 15" (Touch Bar 2017) won't boot
I replaced the battery on MacBook Pro 15" (Touch Bar 2017) following step by step guide and if I open the lid it will display battery icon 100% and then shuts down won't boot or do anything. Not sure what to do.
Это хороший вопрос?
Оценка
0
With the bottom lid removed try and power it on and look for the fans spinning. If they spin that's a good sign but if not check the power button / touch ID connection. Removing this particular battery can be a little difficult. Check for any damage to the track pad connection or cable. Sometimes it's the smallest things.
из Candido Ortiz
@Candido Ortiz they did spin when I plugged the power cord in a two different usb-c ports. They spun for a few seconds then stopped. You stated that that was a good sign. So now what?
из jdcohen1
@jdcohen1 Do you get anything if you press the power button and immediately start holding Command+R on the keyboard?
из Andrew S
