Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586вопросов Показать все
MacBook Pro 2011, I replaced the logic board but can't get it to work
Hello
I have a Macbook Pro from early 2011 and I had problems with the video, I took it to a technician to reball it and it supposedly worked, at the same time it failed again and this time they told me they had changed the video chip.
In the end, it failed again and when I took it to repair it again it did not work again.
I finally bought a used logic board in china and was able to successfully install it as a replacement for the deceased one.
But I have the following problems:
1 The battery or battery charger does not work so the fans run at full speed.
2 I was able to get it to boot but it does not recognize the SSD.
3 I put the original hard disk (unfortunately it had been used for a windows pc) and tried to install different versions of OS
- Yosemite USB installation (failure to finish preloading the USB, the computer restarts and the installation begins again)
- Installation via USB of El Capitan (failure to finish preloading the USB similar to Yosemite) but then I was able to install it with "Clover" and the installable image of El Capitan. The installation was successful but when the mac tries to start it reboots before finishing the progress bar with the apple at the start. This installation only works failsafe and I cannot start the diagnostic mode (D, cmd + D, option + D) nor the recovery mode (R, command + R)
- Recovery using time machine, since I have a copy of High Sierra, I recovered the complete installation but the behavior is the same. Fails to start unless in safe mode.
- Currently installing a minor version (mountain Lion) install the first stage, restart and start installing the second stage. it always restarts after 30% and starts again.
4 In the El Capitan version I uninstalled the drivers for the dedicated video card, hoping that was the problem, but I never got it to boot normally.
I also did all the possible updates and only the installation of "MacBook Pro EFI Firmware Update 2.7" fails because when the Mac restarts to do the update, it restarts again and again and only continues in safe mode. when I look for if something needs to be updated, "MacBook Pro EFI Firmware Update 2.7" reappears
Please if you can tell me what steps to follow or some guide would be saving me.
I am in Argentina and the prices to take this equipment to an official service are exorbitant and unreliable.
Update (08/31/2021)
Hi @danj , you really blew my mind!
First of all thanks for your help and advice, in my many searches I found many of your contributions and they were always very helpful.
I read quite a bit about it and to try and rule out that this was the problem and did the following:
Using my other computer (macbook pro early 2013) and internet recovery I installed mountain lion on a 16Gb pendrive. I put it in the macbook pro 2011 and by pressing option I told it to boot from it.
To my surprise and for the first time it managed to start!
I even managed to install the update "EFI Firmware Update 2.7" ...
My joy ceased when it rebooted for no reason while trying to install the Safari update. (started downloading update and failed)
The mac rebooted again and while loading the OS it rebooted again! This behavior persists as long as a reboot failure occurs and I think I manage to stop this reboot cycle when I hold the power button and turn on again while pressing the option key to choose usb as startup.
As you had indicated to me that the cable could be the cause of the failure. Disconnect the hard drive cable from the logic board. I started again and it rebooted again :( again trying to update Safari.
Just in case, also disconnect the cable from the optical drive.
With both units disconnected it continues to fail.
Currently, it only has a 16 Gb USB as a hard drive.
Since I couldn't update Safari, I downloaded Chrome and managed to install it.
But as soon as I want to start Chrome and the icon starts jumping on the dock while loading, it restarts again ...
Here's my suspicion: Could this be a matter of memory? Currently, it has two 4Gb memories and before doing all these tests I had changed them for two 2Gb and it also failed.
Update (09/02/2021)
Here it is the report I got booting into safe mode
Anonymous UUID:       FA68BE48-FBB3-5DF7-60AE-31C84802DD15
Mon Jan  1 13:45:58 2001
  • Panic Report *
panic(cpu 7 caller 0xffffff800578687f): Kernel trap at 0xffffff7f87f37964, type 14=page fault, registers:
CR0: 0x000000008001003b, CR2: 0x0000000000000033, CR3: 0x00000000092ca000, CR4: 0x00000000000626e0
RAX: 0x0000000000000000, RBX: 0xffffff801e685580, RCX: 0x0000000000000202, RDX: 0xffffff80e614b77d
RSP: 0xffffff910ff7a890, RBP: 0xffffff910ff7a8c0, RSI: 0xffffff910ff7a960, RDI: 0xffffff801e685580
R8:  0xffffff910ff7a700, R9:  0x0000000000000008, R10: 0x0000000000000010, R11: 0x0000000000000000
R12: 0xffffff801e685580, R13: 0xffffff7f87fa7658, R14: 0x0000000000000000, R15: 0x0000000000004006
RFL: 0x0000000000010202, RIP: 0xffffff7f87f37964, CS:  0x0000000000000008, SS:  0x0000000000000000
Fault CR2: 0x0000000000000033, Error code: 0x0000000000000000, Fault CPU: 0x7, PL: 0, VF: 1
Backtrace (CPU 7), Frame : Return Address
0xffffff910ff79d10 : 0xffffff800566ae76
0xffffff910ff79d60 : 0xffffff8005794484
0xffffff910ff79da0 : 0xffffff8005786654
0xffffff910ff79e10 : 0xffffff800561ce60
0xffffff910ff79e30 : 0xffffff800566a8ec
0xffffff910ff79f60 : 0xffffff800566a6ac
0xffffff910ff79fc0 : 0xffffff800578687f
0xffffff910ff7a130 : 0xffffff800561ce60
0xffffff910ff7a150 : 0xffffff7f8636f553
0xffffff910ff7a290 : 0xffffff8005cb7ea7
0xffffff910ff7a2e0 : 0xffffff8005cb79b3
0xffffff910ff7a320 : 0xffffff8005cb5662
0xffffff910ff7a360 : 0xffffff800566ad31
0xffffff910ff7a3b0 : 0xffffff8005794484
0xffffff910ff7a3f0 : 0xffffff8005786654
0xffffff910ff7a460 : 0xffffff800561ce60
0xffffff910ff7a480 : 0xffffff800566a8ec
0xffffff910ff7a5b0 : 0xffffff800566a6ac
0xffffff910ff7a610 : 0xffffff800578687f
0xffffff910ff7a780 : 0xffffff800561ce60
0xffffff910ff7a7a0 : 0xffffff7f87f37964
0xffffff910ff7a8c0 : 0xffffff7f87f4f054
0xffffff910ff7a900 : 0xffffff7f87f4edbc
0xffffff910ff7a950 : 0xffffff7f87f4ed03
0xffffff910ff7a9b0 : 0xffffff7f87f4c4b1
0xffffff910ff7a9f0 : 0xffffff7f87f516d8
0xffffff910ff7aa20 : 0xffffff7f87f55d54
0xffffff910ff7aa70 : 0xffffff7f87f76e08
0xffffff910ff7aaf0 : 0xffffff7f87f781ad
0xffffff910ff7ab30 : 0xffffff7f87f78e9e
0xffffff910ff7ab80 : 0xffffff7f87f70360
0xffffff910ff7abc0 : 0xffffff7f87f74ac1
0xffffff910ff7ac20 : 0xffffff7f87f2cf23
0xffffff910ff7acb0 : 0xffffff7f8635ce99
0xffffff910ff7ad00 : 0xffffff7f8635c34c
0xffffff910ff7ad20 : 0xffffff7f87fffa71
0xffffff910ff7ad60 : 0xffffff7f880230b9
0xffffff910ff7bd20 : 0xffffff7f880244b6
0xffffff910ff7bd70 : 0xffffff7f88025f91
0xffffff910ff7be10 : 0xffffff8005c6b2c6
0xffffff910ff7be60 : 0xffffff7f88009240
0xffffff910ff7be90 : 0xffffff7f880093de
0xffffff910ff7beb0 : 0xffffff8005c6e685
0xffffff910ff7bf00 : 0xffffff8005c7135b
0xffffff910ff7bf50 : 0xffffff8005c73076
0xffffff910ff7bfa0 : 0xffffff800561c557
      Kernel Extensions in backtrace:
         com.apple.driver.AppleSMC(3.1.9)[0249444C-80D4-3184-9060-F70DA3BEB17D]@0xffffff7f86364000->0xffffff7f86380fff
            dependency: com.apple.iokit.IOACPIFamily(1.4)[95DA39BB-7C39-3742-A2E5-86C555E21D67]@0xffffff7f8635b000
            dependency: com.apple.iokit.IOPCIFamily(2.9)[F763C275-306F-358F-B6B0-0FD93486BD5F]@0xffffff7f85e94000
         com.apple.driver.AppleACPIPlatform(6.1)[B0282791-F78C-3A3D-A829-629AD847C7EA]@0xffffff7f87f27000->0xffffff7f87fc2fff
            dependency: com.apple.driver.AppleSMC(3.1.9)[0249444C-80D4-3184-9060-F70DA3BEB17D]@0xffffff7f86364000
BSD process name corresponding to current thread: kernel_task
Mac OS version:
17G14042
Kernel version:
Darwin Kernel Version 17.7.0: Fri Oct 30 13:34:27 PDT 2020; root:xnu-4570.71.82.8~1/RELEASE_X86_64
Kernel UUID: 5E83A13A-32F5-3604-8591-50E2F2F70DC6
Kernel slide:     0x0000000005400000
Kernel text base: 0xffffff8005600000
__HIB  text base: 0xffffff8005500000
System model name: MacBookPro8,2 (Mac-94245A3940C91C80)
System uptime in nanoseconds: 23321620454
last loaded kext at 23023073418: com.apple.kext.AMDLegacySupport 1.6.8 (addr 0xffffff7f88fa1000, size 1187840)
loaded kexts:
com.apple.iokit.AppleBCM5701Ethernet 10.3.1
com.apple.driver.AirPort.Brcm4360 1250.20.1a4
com.apple.driver.AppleIntelSNBGraphicsFB 10.0.4
com.apple.driver.AppleSMCPDRC 1.0.0
com.apple.driver.SMCMotionSensor 3.0.4d1
com.apple.filesystems.autofs 3.0
com.apple.driver.AppleHDAHardwareConfigDriver 281.52
com.apple.driver.AppleHDA 281.52
com.apple.driver.AppleGraphicsDevicePolicy 3.20.18
com.apple.AGDCPluginDisplayMetrics 3.20.18
com.apple.driver.pmtelemetry 1
com.apple.iokit.IOUserEthernet 1.0.1
com.apple.iokit.IOBluetoothSerialManager 6.0.7f22
com.apple.Dont_Steal_Mac_OS_X 7.0.0
com.apple.driver.eficheck 1
com.apple.driver.AppleHV 1
com.apple.driver.AGDCBacklightControl 3.20.18
com.apple.driver.AppleLPC 3.1
com.apple.driver.ACPI_SMC_PlatformPlugin 1.0.0
com.apple.driver.AppleFIVRDriver 4.1.0
com.apple.driver.AppleThunderboltIP 3.1.1
com.apple.driver.AppleBacklight 170.12.6
com.apple.driver.AppleSMCLMU 211
com.apple.driver.AppleMuxControl 3.20.18
com.apple.driver.AppleIntelSlowAdaptiveClocking 4.0.0
com.apple.driver.AppleMCCSControl 1.5.5
com.apple.iokit.IOBluetoothUSBDFU 6.0.7f22
com.apple.driver.AppleUSBTCKeyEventDriver 254
com.apple.driver.AppleUSBTCButtons 254
com.apple.driver.AppleUSBTCKeyboard 254
com.apple.driver.AppleIRController 353
com.apple.driver.AppleFileSystemDriver 3.0.1
com.apple.filesystems.hfs.kext 407.50.6
com.apple.AppleFSCompression.AppleFSCompressionTypeDataless 1.0.0d1
com.apple.BootCache 40
com.apple.AppleFSCompression.AppleFSCompressionTypeZlib 1.0.0
com.apple.AppleSystemPolicy 1.0
com.apple.iokit.SCSITaskUserClient 404.30.3
com.apple.filesystems.apfs 748.51.0
com.apple.driver.AppleSDXC 1.7.6
com.apple.driver.AppleFWOHCI 5.5.9
com.apple.driver.AppleAHCIPort 329.50.2
com.apple.driver.AppleACPIButtons 6.1
com.apple.driver.AppleRTC 2.0
com.apple.driver.AppleHPET 1.8
com.apple.driver.AppleSMBIOS 2.1
com.apple.driver.AppleACPIEC 6.1
com.apple.driver.AppleAPIC 1.7
com.apple.driver.AppleIntelCPUPowerManagementClient 220.50.1
com.apple.nke.applicationfirewall 186
com.apple.security.TMSafetyNet 8
com.apple.security.quarantine 3
com.apple.driver.AppleIntelCPUPowerManagement 220.50.1
com.apple.iokit.IOFireWireIP 2.2.9
com.apple.iokit.IOEthernetAVBController 1.1.0
com.apple.iokit.IO80211Family 1200.12.2
com.apple.driver.mDNSOffloadUserClient 1.0.1b8
com.apple.driver.corecapture 1.0.4
com.apple.kext.triggers 1.0
com.apple.driver.DspFuncLib 281.52
com.apple.kext.OSvKernDSPLib 526
com.apple.iokit.IOSurface 211.15
com.apple.iokit.IOSerialFamily 11
com.apple.driver.AppleSSE 1.0
com.apple.driver.IOPlatformPluginLegacy 1.0.0
com.apple.driver.IOPlatformPluginFamily 6.0.0d8
com.apple.driver.AppleHDAController 281.52
com.apple.iokit.IOHDAFamily 281.52
com.apple.iokit.IOAudioFamily 206.5
com.apple.vecLib.kext 1.2.0
com.apple.driver.AppleSMBusPCI 1.0.14d1
com.apple.driver.AppleBacklightExpert 1.1.0
com.apple.iokit.IONDRVSupport 519.21
com.apple.driver.AppleGraphicsControl 3.20.18
com.apple.AppleGPUWrangler 3.20.18
com.apple.AppleGraphicsDeviceControl 3.20.18
com.apple.iokit.IOSlowAdaptiveClockingFamily 1.0.0
com.apple.driver.AppleThunderboltEDMSink 4.1.4
com.apple.driver.AppleSMBusController 1.0.18d1
com.apple.iokit.IOGraphicsFamily 519.23
com.apple.iokit.BroadcomBluetoothHostControllerUSBTransport 6.0.7f22
com.apple.iokit.IOBluetoothHostControllerUSBTransport 6.0.7f22
com.apple.iokit.IOBluetoothHostControllerTransport 6.0.7f22
com.apple.iokit.IOBluetoothFamily 6.0.7f22
com.apple.driver.AppleUSBMultitouch 262
com.apple.driver.usb.IOUSBHostHIDDevice 1.2
com.apple.driver.usb.cdc 5.0.0
com.apple.driver.usb.networking 5.0.0
com.apple.driver.usb.AppleUSBHostCompositeDevice 1.2
com.apple.driver.usb.AppleUSBHub 1.2
com.apple.filesystems.hfs.encodings.kext 1
com.apple.driver.AppleUSBMergeNub 900.4.1
com.apple.driver.AppleUSBHostMergeProperties 1.2
com.apple.driver.usb.AppleUSBHostPacketFilter 1.0
com.apple.iokit.IOUSBFamily 900.4.1
com.apple.iokit.IOSCSIMultimediaCommandsDevice 404.30.3
com.apple.iokit.IOBDStorageFamily 1.8
com.apple.iokit.IODVDStorageFamily 1.8
com.apple.iokit.IOCDStorageFamily 1.8
com.apple.driver.AppleThunderboltDPOutAdapter 5.5.5
com.apple.driver.AppleThunderboltDPInAdapter 5.5.5
com.apple.driver.AppleThunderboltDPAdapterFamily 5.5.5
com.apple.driver.AppleThunderboltPCIDownAdapter 2.1.3
com.apple.driver.AppleXsanScheme 3
com.apple.iokit.IOAHCISerialATAPI 267.50.1
com.apple.iokit.IOAHCIBlockStorage 301.40.2
com.apple.driver.AppleThunderboltNHI 4.7.3
com.apple.iokit.IOThunderboltFamily 6.7.10
com.apple.iokit.IOFireWireFamily 4.7.2
com.apple.iokit.IOAHCIFamily 288
com.apple.driver.usb.AppleUSBEHCIPCI 1.2
com.apple.driver.usb.AppleUSBUHCIPCI 1.2
com.apple.driver.usb.AppleUSBUHCI 1.2
com.apple.driver.usb.AppleUSBEHCI 1.2
com.apple.driver.AppleEFINVRAM 2.1
com.apple.driver.AppleEFIRuntime 2.1
com.apple.iokit.IOSMBusFamily 1.1
com.apple.iokit.IOHIDFamily 2.0.0
com.apple.security.sandbox 300.0
com.apple.kext.AppleMatch 1.0.0d1
com.apple.driver.DiskImages 480.60.3
com.apple.driver.AppleFDEKeyStore 28.30
com.apple.driver.AppleEffaceableStorage 1.0
com.apple.driver.AppleKeyStore 2
com.apple.driver.AppleUSBTDM 439.70.3
com.apple.driver.AppleMobileFileIntegrity 1.0.5
com.apple.iokit.IOUSBMassStorageDriver 140.70.2
com.apple.iokit.IOSCSIBlockCommandsDevice 404.30.3
com.apple.iokit.IOSCSIArchitectureModelFamily 404.30.3
com.apple.iokit.IOStorageFamily 2.1
com.apple.driver.AppleCredentialManager 1.0
com.apple.driver.KernelRelayHost 1
com.apple.iokit.IOUSBHostFamily 1.2
com.apple.driver.usb.AppleUSBCommon 1.0
com.apple.driver.AppleBusPowerController 1.0
com.apple.driver.AppleSEPManager 1.0.1
com.apple.driver.IOSlaveProcessor 1
com.apple.iokit.IOReportFamily 31
com.apple.iokit.IOTimeSyncFamily 680.15
com.apple.iokit.IONetworkingFamily 3.4
com.apple.driver.AppleACPIPlatform 6.1
com.apple.driver.AppleSMC 3.1.9
com.apple.iokit.IOPCIFamily 2.9
com.apple.iokit.IOACPIFamily 1.4
com.apple.kec.pthread 1
com.apple.kec.Libm 1
com.apple.kec.corecrypto 1.0
EOF
Model: MacBookPro8,2, BootROM MBP81.0047.B27, 4 processors, Intel Core i7, 2 GHz, 8 GB, SMC 1.69f1
Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In
Graphics: AMD Radeon HD 6490M, AMD Radeon HD 6490M, PCIe
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1333 MHz, 0x0198, 0x393955353436392D3034362E4130304C4620
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1333 MHz, 0x0198, 0x393930353436392D3130362E4130304C4620
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 (5.106.98.102.30)
Bluetooth: Version 6.0.7f22, 3 services, 27 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: KINGSTON SA400S37240G, 240,06 GB
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: IR Receiver
USB Device: FaceTime HD Camera (Built-in)
USB Device: Hub
USB Device: Apple Internal Keyboard / Trackpad
USB Device: BRCM2070 Hub
USB Device: Bluetooth USB Host Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 22.1
Это хороший вопрос?
Оценка 0
1 Комментарий
Hi there!
Once again @danj and @mayer thank you very much!
I have great news!
It was just a matter of putting in the battery and the computer just worked perfectly!
I was able to install High Sierra without any problem.
All programs work fine, only the battery drains extremely fast so I am going to contact the seller tomorrow to ask if there are any charging methods that I am not doing correctly.
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
In case that GPU starts acting up again, try installing gfxcardstatus
’ve saved about twenty 2011 15” MBP using this gem, it’s also free ;-)
To turn off the dual graphics capability of the GPU, install gfxCardStatus for Mac
Download  https://gfx.io
This will disable GPU switching and force the MacBook Pro to use the higher powered discrete graphics card rather than the integrated GPU.
  1. Go to the  Apple menu and choose “System Preferences” and then go to “Energy” control panel
  2. Uncheck the box next to “Automatic graphics switching”
  3. Note the text which states this may decrease battery life on the MacBook Pro “When automatic switching is disabled, your computer will always use high-performance graphics. This may decrease battery life.” – if you are not OK with that do not disable this option
  4. Close out of System Preferences
  5. You can always return to the Energy preference panel to re-enable the GPU switching feature if desired.
  6. For MacBook Pro users who want to manually control their GPU use, you can use a third party tool like GFXCardStatus which has been around for quite some time and still works on most modern MacBook Pro models as well.
  7. https://gfx.io/switching.html
Был ли этот ответ полезен?
Оценка 2
11 Комментариев:
Hello @mayer I will follow all of this and will let you know!
из
Hello @mayer
I messed up a bit with the comments and responded to @danj instead of you.
I booted again with the hard disk in safe mode and managed to install GFXCardStatus, configure it to use only the "discrete" board only. But when trying to start, it failed as usual.
I'm going to add a report that I saw when I finished logging into safe mode again as an edit of my question. Could you take a look?
из
Hello again @danj
Unfortunately, there was no luck with gfxCardStatus, I could not install it on my pendrive with mountain lion because they no longer support that OS.
I connected the hard disk again and with "El Capitan" I successfully downloaded the program but I can't change to "Integrated only" because being in safe mode the message that gfxCardStatus shows me is the following: "You can't switch to integrated only while the following item is running: External Display "
Apparently, it considers that I am using an extra screen or something similar, which is not the case.
Any ideas or direction in which to point my cannons?
из
@pumita70 - Did you check my update above?
из
Hello again @danj ! The one who talks about throwing in the towel? Yes, I saw it.
It happens that due to the costs of a logic board and that this is the one that I could buy and above all that I cannot return it because the shipping costs plus the taxes for what I paid would end up losing even more money, it is that I want to exhaust until the last possibility.
из
Показать 6 больше комментариев
It sounds like you’re hitting a known issue when running a newer SATA III (6.0 Gb/s) drive in this series as the original HDD Apple used was a SATA II (3.0 Gb/s). What you’re hitting is the limitation of the original HD SATA cable. Apple didn’t design it well enough to support the faster data flows of a SSD drive!
OK what to do? Time to replace the cable! This is the needed part MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable and yes! Its the 2012 models cable which is the better cable. Make sue you don’t crease the cable as that will damage it, you want to use an old BIC pen ink straw to help form the radius bends when the cable needs to bend. Here’s the needed guide to put it in MacBook Pro 15" Unibody Early 2011 Hard Drive/IR Sensor Cable Replacement
Lastly, you’ll also want to place a strip of electricians tape on the upper case to protect the cable from rubbing Your Hard Drive Cable Is A Ticking Time Bomb to be doubly safe.
Update (09/02/2021)
@pumita70 - I think its time to throw in the towel ;-{
I think the repair shop really messed up your logic board. At this point I would look for a 2012 logic board as that will get you a better discreet GPU.
For reference I'm using right now such a converted 2011 system! The logic board is a direct replacement with one small change needed carefully filing the edge of the LVDS cable tang as the socket is a little wider.
Here's one source: 15" Unibody Macbook Pro Recycled Logic Boards
MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable Изображение
Продукт
$19.99
Оценка 1
3 Комментариев:
After writing this I plan to test the operation with a single memory bank used and in each slot, that is, I will test a SODIMM in each slot to rule out that one or the other fails.
Finally, there is a way to know the reasons for the failures in the console? And if so, could you tell me where and what to look for? Well, for me the amount of information that is shown there is very large and I honestly understand very little.
If there is something that you think I have to do or you need specific information, please do not hesitate to ask me.
Totally grateful to you.
из
@pumita70 - Did you replace the cable? The drive likely needs to be reformatted as its messed up from all of the failed writes.
Beyond that, you maybe hitting the second failure issue of this series the discreet GPU! Follow @mayer instructions, but you first need to stabilize your drive setup first!
из
Hello @danj I didn't replace it yet since I must order it from the capital city.
That's why I where testing with the USB and with the cable disconnected from the logic board.
BTW the sodimm tests didn't produce any good results.
из
Добавьте свой ответ
Jose Rodriguez будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 8
За всё время: 612
