The smaller of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
New battery but still won't charge. Is this an I/O board problem?
I replaced the battery just fine but the new one will still not charge. The power cord and adapter are good.
I/O problem or what else could it be ??
Это хороший вопрос?
Счет 1
1 Комментарий:
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
That should give us a clue on what's happening here.
из
Добавить комментарий
1 ответ
It looks like your logic boards charging logic has failed as your battery current charge is 2050 mAh, yet your charger is connected but not charging! Unless you only just connected the MagSafe charger and the logic hasn’t flipped the ‘Charging with’ and the value ‘0 Watts’ is also altered to a value.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Lou Smith буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 11
За последние 30 дней: 37
За всё время: 344
