Where is this laptop's 24 gb ssd on motherboard?
Hello, i want to change my 24 gb ssd. But, i didn’t found on motherboard when the viewing images. Can i change my 24 gb ssd?
Это хороший вопрос?
Это хороший вопрос?
24GB ? Are you perhaps running off an SD drive?
Specs say there should be a 500GB but obviously your doesn’t have one. There is a SATA port just to the right of the RAM slot:
Asus Vivobook S500CA RAM Replacement
This video shows it as well, with a drive:
https://www.youtube.com/watch?v=xMiO600-...
There are variations in models. Have you got a spare drive you could try it with?
Был ли этот ответ полезен?
Hi @aactech ,
The Asus Vivobook S500CA-SI50305T specs say that there is a 24GB cache ssd via sata 300 (+ a 500GB 5400rpm HDD) but whether it is hard mounted or removable I don't know.
Anyway to my reading cache storage is only for performance improvement by pre loading programs, data etc but how much more than 24GB!! do you need? A lot of PCs only have the cache storage which is integrated in the CPU which is far less than this.
Cheers.
Hi @jayeff
Oh, one of those. Had forgotten about them. Thanks for the reminder.
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 5
За всё время: 401
1 Комментарий
Hi,
Why do you want to increase the SSD cache? Isn't 24GB enough?
из jayeff
