USB microphone on a stand with a headphone jack.
USB Plug Out of Place
Hello, the USB joint on my Blue Yeti microphone is out of place. Somehow while the cable was inside, it got bumped around or yanked the wrong way, and now the USB socket is dislodged.
I’ve watched some Youtube videos about how to fix it, but I don’t have any soldering equipment. Do you have any suggestions on how I might fix this?
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (1)
unfortunately without any soldering equipment to reseat the joints the only alternative is to send it to someone who does have the capability to fix it. typically its not very expensive to have done.
usually you can get a decent soldering iron from amazon and some solder and flux. it just depends on what you want to do.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Rose Whitcomb будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 3
За последние 30 дней: 17
За всё время: 736
