Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794вопросов Показать все
Need a replacement wifi/bluetooth cable
I recently replaced all the speakers on my laptop as they were broken. While doing this, I accidentally broke the wifi/bluetooth cable. Is there anywhere I can get a replacement cable for my mid 2010 macbook pro? I found one on the ifixit website for the 2011-2012 macbook pros. Is this the same for the 13in mid 2010 macbook pro?
Thanks for the help in advance!
Это хороший вопрос?
Оценка 0
3 Комментариев
Can you post a few picks so we can see whats damaged Adding images to an existing question
из
Thanks for your reply Dan! I just added a picture of the cable that's damaged.
из
Update: was able to fix it by properly straightening out the pins and insert it into the connector. The internet and Bluetooth work!!
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Just in case, here’s the needed cable 13” MacBook Pro, Airport/Bluetooth/iSight Cable, Apple P/N 661-5558. Here
s the guide you’ll need to follow MacBook Pro 13" Unibody Mid 2010 LCD Replacement We don’t have a direct guide for the data cable but is’t pretty straight forward once you open things up.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
ADS будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 72
