This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316вопросов Показать все
Nintendo DS won't turn on. Green light flashes then turns off.
I am trying to fix a Nintendo DS Lite but not sure what the problem might be, and what to try to narrow down the issue.
When the power adapter is plugged in the orange light turns on so I don’t think the power adapter is the issue.
When I flick the power switch the green light comes on, then gets slightly brighter. Then the lower screen flickers (what I assume to be the backlight) and it switches back off (with the green light off and the orange one still on) This behaviour is the same without the orange light when not plugged in to the power adapter, so I assume it is holding at least some charge?
Any help would be much appreciated. Thanks
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Hello! I had this same problem when doing a shell swap on my DS Lite and also repairing an original DS. This happens when the screen ribbon cable is ripped or the screen is broken. I would check both screens and ribbon cables and make sure they are both plugged in all the way. I was able to fix this problem with my DS by taking out the top screen ribbon and plugging it back in. Good luck with your repair!
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Mayank будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 18
За всё время: 173
