Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
552вопросов Показать все
Trackpad physically clicks but isn't responding
My MBP has been having this issue for a while now. I even took it apart to check to see if the battery is swollen but that’s not the case here. I’ve done a PMC reset too, didn’t do anything.
My trackpad at one point was getting stuck and unable to physically click I managed to get it unstuck by pressing around the trackpad except it still doesn’t recognize or respond to the physical click.
I have tap to click enabled in the meantime to get by but would like to see if there’s a solution. I’ve read how many people were smacking/hitting their trackpad and that managed to fix it. Does anyone have the same problem before and how did you fix it?
Thanks!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
The Click action is achieved via a physical blister switch which sits on the back side of the trackpad
So if the trackpad is not physically moving you likely had junk jamming the edge preventing it from moving. If the trackpad is moving then either the adjuster needs adjusting or the trackpad its self has failed. I’ll warn you its a big job! And I often also take the time to replace the battery as well as I’m sure your’s is getting to the end of its life. Let’s get a better view of things with your battery, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
In any case here’s the needed parts:
Here’s the guide to put both the trackpad and if needed a fresh battery MacBook Pro 13" Retina Display Late 2013 Trackpad Replacement
I would follow the guide removing the trackpad so you can clean the edge of the case using some kitchen cleaner and a paper towel (wetting the towel) getting the grit and gummy mess off. Do the same on the trackpad edge as well but you want a fairly dry towel as you don’t want the cleaner to wick into the layers of the trackpad.
To adjust the click plate, carefully rotate this screw a quarter of a turn at a time as you don’t want to allow the screw to come out. Test things by pressing the Trackpad until you here or feel the click action of the switch.
MacBook Pro 13" Retina (Late 2013-Mid 2014) Battery Изображение
Продукт
$99.99
MacBook Pro 13" Retina (Late 2013-Mid 2014) Trackpad Изображение
Продукт
$49.99
iFixit Изображение
Инструкция
Сложность:
Очень просто
2 - 5 minutes
MacBook Pro 13" Retina Display Late 2013 Trackpad Изображение
Инструкция
Сложность:
Сложно
1 - 4 hours
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
jaded x будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 128
