Hard shell for the screen cracked
Just found out my laptop was cracked,
Please help.
Thanks
Это хороший вопрос?
Please help.
Thanks
Это хороший вопрос?
This was a common issue in this series. The polycarbonate case often cracks at sharp inside corners like this.
Using some 95% or better isopropyl alcohol flush out the gap of any junk using a syringe with a small needle and a few short blasts of can’ed air. Then use DAP-RapidFuse Clear All Purpose Adhesive should be enough to hold things. Make sure you have a way to press the two sides together once you get the glue in (move quickly) Don’t touch the area and hand holding is not good enough.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 35
