Why when I turn on does it just stay trying to load?
I turn on screen and it just shows the spinning load symbol in the middle and never goes past that
Это хороший вопрос?
Это хороший вопрос?
The drive is having problems! The drive boot loader is getting loaded but it gets lost at that point.
You’ll need to find the grey disks that came with your system or find a friend who has an older Mac with macOS 10.12.x Sierra or older to create a bootable external drive for you. Then you can boot up under it. Or, Bring the two systems together so you can connect them together via FireWire so you can leverage your friends system as the boot drive. The for either method run disk Utility to check and fix your drive if you can.
References:
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 11
