Guides for the Wi-Fi version of the iPad mini 5—model A2133. Released in March 2019, the iPad mini 5 is the successor to the iPad mini 4.
8вопросов Показать все
I need a Permanently remove iCloud Activation lock
Hi,
if it’s ok on here to ask this for a iPad I legally own. I need to find someone who I can pay to do a permanent removal of a iCloud activation lock on a iPad mini 5, ‘Wi-Fi only’ can anyone recommend to me who I should contact to get this done?
Это хороший вопрос?
Оценка 2
1 Комментарий
so you own it but its locked with somebody else's applid and password ?
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Well, it’s easy for technician to remove icloud of IPad that is Wifi Only, by removing the hardware or from the software. You can ask it to technician iPhone that can remove icloud to remove it. But beware of scam, even though it’s easy to know which is a scam or not for those who know the basic process of removing iCloud by a paid tool, or Bypassing iCloud, because usually they scammers don’t even know the proccess of jailbreaking (the most basic of removing iCloud), and so on, but some people still get scammed.
So, the conclusion, yes you can ask the technician to remove iCloud, as long as you are the legally real owner, and can differentiate which is scam or not.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
For this model or any ipad with A12 CPU . Hardware metode is not possible. If you change the SN and WIFI address on these models . You cannot active it . It will stuck on activation(Unable to activate, Error ) because of the new CPU design. It doesn't matter if it is wifi only or cellular.
из
Добавьте свой ответ
Gary будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 9
За последние 30 дней: 45
За всё время: 851
