What is the middle battery connector for?
After Ipod touch battery replacement the battery has been getting stuck at 19% or less
then when it gets low enough the ipod shuts off,
and it take a while to get it to start up again with it plugged in,
Is it possible i got a defective battery?
Это хороший вопрос?
Оценка 1
14 Комментариев
@beanman56 it's possible. where did you get it from?
из
I got my battery from ifixit,
so whats the middle connector for?
из
@beanman56 On the 6 gen I am pretty sure the centre pin is the battery data.
из
Is it needed?
Cus it was ripped off the board
из
@beanman56 Usually one or more pads come off when this happens. How’s you’re soldering skills?
из
Показать 9 больше комментариев
Добавить комментарий
Ответов (1)
Выбранное решение
Hi
Hope you are well
I did not know really know how to explain this but I had a 6th gen that had the middle battery connection ripped off from previous repair and I noticed that mine would get stuck at 17% and when it would die it straight up wouldn’t charge again but there are test pads above the 3 battery pads and I found the one in the photo had a connection so I ran a jumper and it started working again so hopefully my complex explanation as helped
Anymore questions please ask
Был ли этот ответ полезен?
Оценка 2
10 Комментариев:
Whats a jumper
из
@beanman56 A jumper is copper wire that you use when a trace or pad is broken between components. The average size wire is 0.01mm
из
@hellomacos - What size should said jumper be?
из
@beanman56 where you been Sir? Doing ok?
из
Показать 5 больше комментариев
Добавьте свой ответ
Ben Capehart будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 476
