Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
740вопросов Показать все
usb ports are not working properly if usb pen inserted completely
when inserting mouse or external memory sticks, they are not spotted. If I take it ot just a little, they are spotted and working. the problem is that if I move the laptop, then the connection is lost.
how can I fix it?
Update (11/02/2021)
Coudn’i it be that the pins need just to be pushed a little bit so that the contact between port and jack is more stable?
Это хороший вопрос?
Оценка 0
2 Комментариев
Are you encountering issues on just one port or both?
из
to both of them. !
из
Добавить комментарий
1 ответ
Выбранное решение
Your system only has USB 2.0 (480 MBit/s) by chance are you plugging in a USB 3.0 (4.8 Gbit/s) {also called USB 3.1 just to confuse you!} Cable/device?
One of the issues between 2.0 and 3.0 is a set of extra pins in it connection!
See if a USB 2.0 cable/device works. I’m suspecting the extra pins are shorting out when you push the cable in.
Reference: 5 Fast Ways To Find Different Between The USB 2.0 And USB 3.0
Был ли этот ответ полезен?
Оценка 0
6 Комментариев:
Thanks Dan. However the problem is happening with an external hard disk that was working perfectly till a few days ago (same thing for a mouse). So I do not think is a USB 2.0 vs a USB 3.0 issue…
из
@stefanochi - If that's the case your logic board will need repairs as the ports are port of it and the logic within it might be messed up.
из
из
@stefanochi - A bent pin which is shorting is what I was thinking at the start but if both ports are having problems that tells me its either a bad cable or something deeper.
из
Cables are OK because are working properly on other pc's
из
Показать 1 больше комментариев
Добавьте свой ответ
stefano будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 43
