MacBook Pro freezing then turns off
Hi,
I have a Macbook Pro 2015 and it randomly freezes and turns off. However, I’ve found this doesn’t happen if I unplug the battery and just run it plugged in to the power.
I’ve updated it to Big Sur and tried another SSD, as well as SMC reset etc.
Coconut Battery says it’s in good shape, but 723 cycles.
Is this a battery issue? It probably is but just want to make sure before I spend $100 or so on a new battery.
Thanks!
Это хороший вопрос?
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
из Dan
Thanks for replying. I've added the battery info.
Im starting to think maybe it's an overheating/fan issue?
из JoolzD
@joolzd - If thats the case install this great app TG Pro it will allow you to see more discreetly what's happening. Post a snapshot making sure you get all of the sensors and fan in the image use the keyboard (Control, Shift and 5 keys) its a bit easier and a snap from your phone.
из Dan
