The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
MacBook Air totally unresponsive to power up
My laptop is unresponsive to any attempt to turn on. I did the SMC and NVRAM resets, I opened and inspected and found nothing unusual, I unplugged the internal battery and attempted to boot with just power cable, I’ve held the power button for extended period, I tried shift+ power long hold.
Nothing has worked. When I push the power button, I hear barely a moment of electronic noise or fan creep and then it dies instantly but this is not consistent.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Выбранное решение
Not good ;-{ From what you describe your logic board has issues.
So you might find someone with the needed tools and skills to fix your logic board or you could just replace it. But the expense of replacing it given this series limitations may not be worth it MacBook Air 13" Early 2014 Logic Board Replacement
Maybe it’s time to look at the used systems market for a newer version like the 2016 or 2017 models.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Andrew будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 54
