Repair guides and support for tablets produced by Lenovo including the ThinkPad tablet line.
Why is my Tab M10 not turning on
Good day, I have a Lenovo Tab M10 HD provided to me by my college. It is not starting at all, when on charging the tab repeatedly turns on and shuts down in a loop. When on battery the Tab does not start at all no matter how long I press the power button. Please advise on how to fix this issue
ReplyForward
Это хороший вопрос?
Оценка 0
4 Комментариев:
What happens when you hold power+volume down for a few seconds while the tablet is plugged in to power?
из
Nothing happens it just keeps going to the lenevo logo on boot up then shuts down , then the cycle repeats
из
I have the same problem, but my tab its not turning on, its only doing a vibration no matter how many time i press the power button, it doesnt turn on.
One time i turned it on, it worked for some Hours and then it stopper working again
из
Hii, Did you find any solution?
из
Добавить комментарий
Ответов (1)
@nemoo “when on charging the tab repeatedly turns on and shuts down in a loop. When on battery the Tab does not start at all” start off by replacing the battery. A depleted battery will exhibit the exact symptoms you are describing.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Captain будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 4
За последние 30 дней: 15
За всё время: 1,229
