Apple's 2016 revision to their laptop lineup targeted at professional users. Features a 15-inch, 2880-by-1800 Retina display, quad-core Intel Core i7, 256 GB / 512 GB /1 TB / 2TB storage options, 16 GB RAM, and a keyboard equipped with a Touch Bar. Released November 2016. Features Model A1707.
260вопросов Показать все
Keyboard and trackpad not working
Macbook Pro was working fine last time I used it a few weeks ago. Its been powered off since. Started it up today and the keyboard and trackpad dont work. Connecting external keyboard and mouse work fine. Cant boot in safe mode to troubleshoot, again because the built-in keyboard doesn’t respond.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Apple loves making things complex!
If I remember correctly the TouchPad logic is also the USB driver logic for the keyboard. So I’m suspecting you might have had a spill or you used some cleaner which seeped under neath damaging the logic board. Here’s the needed part MacBook Pro 15" Retina (Late 2016-2019) Trackpad and here’s the guide to put it in MacBook Pro 15" Touch Bar Late 2016 Trackpad Replacement
While you’re in their check the keyboard cable connector for any corrosion
MacBook Pro 15" Retina (Late 2016-2019) Trackpad Изображение
Продукт
$69.99
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Thanks, I'll check in to this. There were no spills or anything and I dont use any cleaners on the keyboard or track pad. Its just odd it all of a sudden stopped working.
из
@sharkdiver72 - In that case the Touch Bar cable would be suspect. What can happen is the batter swells up and presses on it damaging it MacBook Pro 15" Retina (Late 2016-2019) Trackpad Cable. That was less of a problem in series.
из
Добавьте свой ответ
Brad будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 207
