My phone is wont open.
My phone wont open. The loading screen stops for hours.
Это хороший вопрос?
Это хороший вопрос?
If you have an iPhone X or later press volume up Volume down and then hold power that will hard reset your phone
if you have an older phone iPhone 8 plus or older hold the power and home button down until the screen shuts off to do a hard reset
if then it still does not work I would probably connected to iTunes make a back up and then reset the phone however that will not help if there’s a hardware issue
Был ли этот ответ полезен?
The person asking the question has an Android, not an iPhone.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 89
Is the phone still stuck on the loading screen or can it be shut down?
из Andrew S
i can turn it off
из Anonymous
@anonymous_user Turn the phone off, then hold power+volume down for a few seconds. Do you see anything on the screen?
из Andrew S
question mark inside battery icon
из Anonymous
@anonymous_user Is that when the phone is plugged in or unplugged?
из Andrew S
Показать 1 больше комментариев
