A zipper found on clothing and gear to keep everything zipped up!
My Nano puff jacket is getting difficult to engage zipper & start zip
Zipper does not easily engage anymore & start zipping up, teeth all appear fine & the bottom is not excessively worn or frayed
Это хороший вопрос?
Счет 0
Добавить комментарий
3 Ответов
Put a single drop of fine oil, like sewing machine oil on the zipper and open up and close the jacket a few times. Should become much more usable!
Был ли этот ответ полезен?
Счет 0
You might try chapstick on the zipper this is similar to a product that was out eons ago that our grandparents used to use I don't find it for sale anywhere but it is very similar to chapstick hope that helps
Счет 0
I have very carefully used pliers to squeeze each side of the zipper pull a bit closer together. If you are not careful, you can break the pull.
Счет 0
Добавьте свой ответ
marc robertson буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 36
За всё время: 525
