Seagate external HDD Drive 8TB Model#: SRD0PV1 Models of differing size likely have the same casing.
3вопросов Показать все
How to hook up 6TB seagate backup plus drive without housing
The connecting port of my drive got damaged and my laptop won’t see the drive. Can I replace the housing or buy a different housing that will allow me to use the drive without the Seagate backup plus housing? Thanks!!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
You could potentially just “Schuck” the drive. Meaning pull out the HDD and throw it into a external HDD case.
Seagate Backup Plus Hub Teardown
Seagate Backup Plus Hub Repair
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Thanks for taking the time to reply, it's much appreciated! I got as far as taking the drive out the case but I am having a difficult time figuring out what kind of case is compatible. Out of my depth slightly :)
из
Добавьте свой ответ
nadja7765 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 8
За всё время: 119
