Can't control the brightness after screen replaced
Somehow the brightness control has disappeared from the display option as you can see on the picture.
It’s an A1706 EMC 3163
any idea what would be the cause?
Это хороший вопрос?
Это хороший вопрос?
Sadly, Apples newer versions of macOS has now enabled display ID check so off brand (non-Apple units) now have issues. Talk with your supplier to see if they offer a solution, otherwise you’ll need to get a recycled real Apple display instead. And no, reverting to an older version won’t fix this. The alteration is within the systems firmware update and you can’t really roll it back.
Был ли этот ответ полезен?
They said to swap the screen but no guarantee the new one will work, I will go for second hand one I think :)
Any idea where I can get the write part # for my mac book? Found this http://www.powerbookmedic.com/identify-m... but not sure if it's accurate
The link you offered is just to the system ID offering, not the part its self. If you’ve selected the correct system then here is what you need
2016/17 - 13” MacBook Pro Display Assembly:
∙ Space Grey - Apple P/N 661-07970
∙ Silver - Apple P/N 661-07971
As for a source to buy one you could use iFixit MacBook Pro 13" Retina (Late 2016-2017) Display Assembly or BeetsTech BeetsTech 2016/17 screen or TheBookYard UK 2016/17 screens These are my goto places.
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 15
За всё время: 1,185
Did you have the display assembly replaced?
из Dan
Yes, and i have bought from https://www.accupart.co.uk/products/appl...
из Yass O.
