Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
429вопросов Показать все
does not power up
does not power up. changed power supply and changed bios battery. result is a blinking led1 on the motherboard. bios battery was at 2.87 volts. do not know how to test power supply. any clues?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
How dusty was the system when you first opened it up? Did you check the GPU MXM board?
A common issue in this series is the GPU board fails and depending on how it fails it can short out causing your single diagnostic LED to blink.
Are you a hard user of the system? Running heavy graphics like large photo or video editing, video rendering or gaming? This system series can’t handle most of this.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
drpalomo будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 20
