Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Repair guides for displays (or monitors) for computers or other devices with video output.
252вопросов Показать все
Why my Dell LED in2030 display vibrating?
dell in2030m(VGA)
1600x900 at 60hz
ati 6750 1gb
I cheaked with another monitor same problem... shaking in display? :(
also I cheaked on Board VGA port
desktop Board DH61ww+ i5(3.0GHz)-2320
sry fr my bad english
Это хороший вопрос?
Оценка 0
Комментарии:
Try booting it to the BIOS to see if the screen shakes there. If it shakes in the BIS it is definitely hardware related. It could be a bad video or display driver if it only does it in Windows.
из
My monitor blinking 3-4 times per Second . What can i do now?
из
Hi @S.M RAKIBUL ISLAM,
What is the make and model number of your monitor?
Did you try another monitor connected to the source of the signal to prove whether the problem is with the monitor or the source of the signal. e.g. is it the computer or the monitor that is the cause of the problem?
Does the monitor's OSD (on screen display) menus stay on and not blink?
What have you tried?
из
Добавить комментарий
Manta Driver Kit
112 bits for every fix.
Upgrade Your Toolbox
Manta Driver Kit
1 ответ
Наиболее полезный ответ
Here are some basic troubleshooting steps:
1. If the picture on the screen is vibrating, or seems like it's shimmering etc, it could be the refresh rate is set improperly on the monitor or the resolution is too high.
2. Before we go there, however, the quickest first thing I would do is just press the menu button on the monitor itself and access the monitors menu to do a factory reset. Sometimes you get lucky.
3. Ensure the monitor cable is tight on both ends. Shut off the monitor, reseat the power and monitor cable, then turn it back on. If you have another cable, test it with that to rule out a bad cable.
4. Make sure the monitor isn't near anything magnetic like speakers or microphones etc, or anything which gives off waves of any kind. Like a wifi router, etc. This shouldn't affect newer lcd models, but you never know.
5. If that doesn't help, check your refresh rate and resolution settings under the display options in your control panel. If you have it set to it's highest resolution 1600 x 900 move it down to the next lower resolution. If you just replaced a CRT monitor, maybe you have to increase the resolution/refresh rate to 1600 x 900 and 60 mghz.
6. Lastly, if all else fails, and all the hardware appears to function properly (test the video card with a non-lcd monitor, for instance, and see if that works) then I would update the video card drivers.
Let me know if any of these things worked, and if not, we can maybe figure something else out.
Был ли этот ответ полезен?
Оценка 3
Комментарии:
thank you ,sorry i don't know good english. im using win7 ultimate 32bit also i cheaked monitor with another system no problem working good at 1600x900(windows xp) i bought that monitor 2days back, it support (DELL IN2030M)1600x900 at 60hz highst i conected my old monitor (1400x900) same problem ... yes, i cheaked witha another monitor and vga cable no use :( and i downloded latest drivers for ati 6750... still same problem yesterday i contacted intel techsupport they told me its powersupply problem?? please help me?? :(
из
+ very nice answer Nate
из
Добавьте свой ответ
karty будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 20
За последние 30 дней: 130
За всё время: 7,131
