My PC won’t boot into bios and when booting into bios freezes
When it’s shows no signal before the ram was working then while it was booting I removed the ram causing it to explod 2 days after I ordered new ram and no signal things I’ve already done : reaseated the ram
Reaseated the cpu
Reinstalled gpu connect some
Power cables back such as cpu and sata
Nothing works
Это хороший вопрос?
Счет 0
1 Комментарий:
You have probably damaged the RAM and/or the memory controller chip.
If you take out the RAM will the computer power on?
из
Добавить комментарий
