Coffee brewmaster released in 2013. The Keurig K40 is a k-cup compatible coffee maker.
30вопросов Показать все
Why wont my keurig make a full cup of coffee?
hi … i have a keurig k40 …that every couple months decides to not make a full cup of coffee … tried everything shown in info i seen on this site…last couple times i had this problem …on the top theres a check valve that i took apart ..cleaned etc and watever i actually really did im not sure ..but works than for a month or 2 same issue …would it help changing check valve ? or would this k40 have a solenoid that could be causing issue ?
Это хороший вопрос?
Оценка 1
2 Комментариев
Hello, does this issue happen when you use a K-Cup or do you use one of the reusable cups?
из
i would say it happens with both k-cups and reusable cups ...also if i just fill a cup of hot water alone .. does this as well...
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
From what I can gather it might be that the needle that is used to puncture the K-Cup might be dirty. You can take a paper clip and see if that will dislodge any grounds that might have built up. Otherwise I would check your water pump, as that might be causing the issue.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
i have cleaned needle as well ...still causing issue .... put water pump in vinegar still giving issue ...put a dfferent water pump from a different keurig on there ...still giving that issue so im wondering if it could be a solenoid ?
из
@norbie I would definitely try that next and see if that has an effect on the issue. Thankfully a replacement part doesn't seem to be insanely expensive if you want it brand new.
из
Добавьте свой ответ
Jeff будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 225
