How can I fix t612 loose 30 pin dock. Unit works thru aux port
Repair shops won’t do it claim micro soldering involved
Это хороший вопрос?
Это хороший вопрос?
Micro soldering is required for most connector repair, there could be someone local to you that does this type of work
Был ли этот ответ полезен?
you COULD try hot gluing the connector - fix it in place with gaffer tape, and one dash of gun glue at a level plane with the bottom of the connector bowl.
If you are hearing crackling noises also, when connecting your 30 pin i-device, it could be the connector, but could also be interference. Google it, then.
Hot gluing wouldn’t repair the solder joints.
I was apparently asleep during reading. My apologies.
microsoldering of 30-pin
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 89
