The 2018 version of the Samsung Galaxy A8+ smartphone released in January 2018.
Вопросов 20 Показать все
My phone went off problem with battery not showing amp
My phone went off when I restarted it at 8% battery and was still plugged into the charger. I went to Samsung authorized center for a fix. They told me that the battery wasn’t showing the 1.2 amp power on their device and it’s not booting up. I asked them to replace the battery or check the charging port they keep saying that it’s not the issue. Is there a possibility to get it turned back on because they said if it won’t work then the whole motherboard is required to be changed. Also, he said that he will try with a wireless charger to see if it helps in powering up but my phone isn’t wireless charging capable.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Yogendra Vaghela regardless of what anybody says, I would replace the battery first. That will at least give you at least a known-well starting point.If that does not work, follow the flowchart for the No Power situation.
Board layout right here Samsung 8+
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Yogendra Vaghela будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 155
