Replaced 9.7" screen, can't get it to close.
Howdy all!
I replace the screen on my 9.7” pro. Broke the home button cable, so I had to wait for a replacement. Got that moved over. Reassembled except for sealing the screen, and everything (other than touchID) worked. Screen seemed to align with the case, so I pulled the tape, and closed it up. Looked good, very happy.
The next day the bottom of the screen popped up. Thought I just didn’t press into the adhesive enough, so went around the edge, and it looked good again. But later the screen popped up again.
Looking closer, the LCD cable has a bend in it where it wants to come out of the shield, go straight up into the gap between the inside case edge and LCD, do a 180 downwards, and then bend 90 to the panel. I tried getting that blip to go into the side of the case, under the tab that gets taped, but it is persistent. I can’t get the cable to lay flat enough for the bottom half of the screen to sit flat.
Should the extra cable loop into the side of the case, under the edge that gets taped? How do I train this cable to go to the correct path so I can reattach the screen to the case?
Thank you.
Это хороший вопрос?
