How to fix YLOD permanently
Это хороший вопрос?
Check out my PlayStation 3 Potential YLOD Fix guide. To complete this guide, you will need to know how to microsolder.
Был ли этот ответ полезен?
What do you mean by microsolder?
Can't I just change the thermal paste and use a heat gun?
@nytryder26 No, that's only a temporary fix. The permanent fix is to replace the NEC/TOKIN capacitors, which requires SMD soldering.
YLOD is not a problem, it’s just a symptom.
To fix a problem, you need to find it first. Blindly replacing things won’t work, fix things that are broken is the actual right thing to do.
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 2,018
Send the console to Sony, pay them upward of $150 to repair it, and wait around 6 weeks to get it back in working condition.
Send your console to a local repair centre.
из Carlton Flores
@celalsur They fixed it last time and it only worked for a month or 2
из NR26
