Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
429вопросов Показать все
2.5 Crucial SSD SWAP wires
I followed all the install photos and directions. It’s just the connection forces the wires out instead of underneath with the new thermal sensor. Just want to make sure it’s okay before closing. Any suggestions, I’m open.
Это хороший вопрос?
Оценка 0
2 Комментариев
Are you replacing your HDD or adding it as a second drive?
Can you post a picture so we can see what you are encountering Adding images to an existing question
из
@danj Hi, sorry I thought I had uploaded the picture. Here it is. Let me know if you need more. I replaced my HDD with the Crucial 1TB from iFixit. The only thing is the temperature wire harnesses makes the previous connection a little more cumbersome. I just want to make sure before I close that it’s acceptable.
из
Добавить комментарий
1 ответ
Выбранное решение
After comparing the photo you attached with photos from our teardown for this device, I don't think you'll have any issues with that. It looks to me like the issue is caused by a different shape in the fact that you have to use an adaptor to fit a standard-sized SSD where the old big-disc hard drive went. Worst-case, I would just use some basic electrical tape to secure the wires similarly to how they were before you replaced the drive.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
John Gliatis будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 22
