There are vertical lines in my screen.
Where can I get a reasonably priced replacement and installation instructions?
Это хороший вопрос?
Оценка -1
Добавить комментарий
2 Ответов
Выбранное решение
Most likely needs a ATI GPU video repair if it's not the capacitor problem mactech spoke of. Open the machine by taking out the three screws on the bottom of the frame and examine the cans for corrosion of the tops, or bulging. Please take a look at this post for comments on problems on this type machine.
do you sell replacement logic boards for this computer
Был ли этот ответ полезен?
Оценка 2
You can try DT&T services to get a replacement board installed at DT&T service.
http://www.dttservice.com/iMac.html
But I have a unit that came in from a client that had the board replaced by Apple and it failed after a year. The G5 iMac is really a waist of money. Would suggest cut your loss and buy a new intel iMac. The unit is strong and reliable.
There is a kit you can get to replace the bad Capacitors on the logic board which is most likely the problem but it is hit and miss. Here are the instructions:
http://www.jimwarholic.com/labels/iMac_G...
ken
Оценка 1
Добавьте свой ответ
Frankie будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 3,979
