mine JUST randomly started just now, i had the same exact problem.. and heres how it first happened:
i switched to a lower end tv, i switched the hdmi and power cords, i turned on the ps4, i tried connecting the controller but it wouldnt connect even though it charges and everything (the orange light is showing too), so i turned off the ps4 with the controller plugged in, i did 3 beeps by accident and didnt realize the ps4 was turning off, i then waited 2 or 3 mins after it officially turned off, i then did the 2 beeps going into recovery mode, i reset the controller a cpl times before unplugging the ps4, i waited a min or 2 before plugging the power cord in, turned on the ps4 again, reset my controller again a cpl times, unplugged it again waited a min or 2 (controller is plugged in this whole process), plugged it again, did the 2 beeps turning off the recovery mode, turned it off and turned it on one more time going into the blue screen, made sure the controller was charging, then i pressed the ps button and it finally randomly connected to the ps4.
im not commenting a solution, im just telling yall the story on how i got mine fixed.
P.s now i have another problem, the controller suddenly died and now it doesnt want to turn on or either charge. I tried plugging the controller into different usb plugs but it still wont charge or turn on. This happened RIGHT after i finally got past the press the ps button screen. smh. its the only controller and charging cable i got right now so i havent tried those options out yet. I just hope that it is only the charging cable. its so weird too because this controller was JUST charging, (thats how i got past the press the ps button) but its like the controller or the charging cable just randomly died. as they were working not too long ago lol idk
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
0
Отмена
Прокрутите эту тему, чтобы найти подходящее место для этого комментария. Затем нажмите «Прикрепить комментарий к этому сообщению», чтобы переместить его.
2 Комментариев
I have same problem will not go past this screen saying connect dual 4cord n prepsps button nothing happens
из Mike Ritz
Same it won’t work when I press the button
из Justin Paris
